I'm interested in a portable gaming rig (it'll also be used for light photo/video editing) and given the choice between a gaming laptop or an SFF build, I prefer the latter (cheaper, more bang for the buck, I like building things). The plan right now is to build an SFF rig using the Silverstone SG03 and to transport it with the sugo pack. Not sure how relevant this is, but I'll be transporting the system from the US to Argentina as carry-on (assuming that's possible, I haven't asked yet - hopefully it is).
Anyhow, I've been kicking around ideas, and I'm looking for some advice. Since I'll be in Argentina for the foreseeable future, my primary concern is component reliability (looking for quality, no over-clocking, needs to run cool) and warranty/customer service. Quite frankly a C2D system with an upper-mid range graphics card should fit my needs just fine. That being said, if it's possible, I wouldn't mind putting in the latest and greatest, as long as it meets the above requirements for reliability.
I just started (literally a few hours ago), but here's a rough idea of what I'm considering:
Latest-Greatest Build
Mobo MSI P55M-GD45 LGA 1156 Intel P55 Micro ATX Intel Motherboard or
EVGA 121-LF-E652-KR Intel P55 Core i5/i7 Socket 1156 PC3-16000 (DDR3-
2000) mATX Motherboard Retail
(going to wait for reviews)
Processor i7 860
Graphics Card Nvidia GTX 260
Before I even look into anything else, is this feasible? For cooling, the plan is to use a Corsair H50 and either modding a blow-hole in the top myself or buying from performance-pc and having them do it for me. Do you think this would run hot or do you think it would work? If that won't be enough cooling, any other suggestions for either more cooling or swapping components to make it work?
C2D Build
Mobo Unsure - any suggestions (emphasis on no over-clocking and reliability + upper
mid level graphics card capable)?
Processor Intel E8500 Wolfdale 3.16 ghz 6 mb
Graphics Card Unsure - I prefer Nvidia (upper mid level graphics, best one that the mobo can
run, less than $200)
Would the stock cooling be enough or should I still plan on using an H50 or some other cooling solution? Could I get by without the blow-hole or with a pci slot fan?
If the first build is feasible, I'd like to give it a shot, but otherwise a C2D build should meet might needs just fine. Anyhow, open to any and all suggestions and/or pointers to things I may be overlooking. Hope you can help!
Cheers,
MB
Processor i7 860
C2D Build
Cheers,
MB
