Nice, thanks!
Ah, is that why you removed it, the wallpaper comment? I thought they were talking about the PC wallpaper
No it doesn't.. you can always add more (cheaper) cards.
Two video cards and ultramon, yes.
And those are 20" Dell 2001FP's.
Any card that has at least one dual-link DVI port. Anything less and you won't achieve the full native resolution of the display.What graphic cards run at this ultra high resolution?
if you're planning to run this monitor at 2560x1600 in a gaming environment without 1:1 pixel mapping. You'll probably want to know...at this resolution, SLI/CF is recommended if you normally go heavy on eye candy/AA/AF.
Although I haven't researched into this monitor as much as I would love to. Not sure if it has 1:1 pixel mapping.
Darn though! If this monitor was a IPS panel..I would pick it up for sure. I'm still contemplating between a dell 3007wpf-hc, this, a nec 2490, and a refurbished a- grade FW900 with a 1 year warranty. Damnit...Making up your mind on monitors is just too damn difficult.
*edit* damn.. you beat me to it.. I R Loser...
Mwhahahah!!11!1...hahaha. Your edit gave me a good laugh. But yea, I've given a brief look into the monitor and got a bit upset at the pressure point defect with the cross like screw. It turned me off considering how ill received the customer support was from gateway. But after I read the solution was just in a small first batch..the ill taste was lifted. The only issue I see now is the PVA panel. If this monitor had a IPS panel..IMO it would be the perfect monitor for me...=(
OHH THE SORROW!
You can't always have it your way, this ain't burger king you know.
But yeah, although IPS would have been great - it would've added much more to the overall price. Plus, this is still a damn fine monitor as it is.
Indeed. I wanted a IPS panel since color accuracy is important in my work. I'll probably end up getting a Nec2490WUXI...Or just nabbing a refurbed fw900 from accuraiteit till FED/OLED become the norm....
bah..I keep making up my mind to one thing then changing it the next day.
Alot of cards run at the native resolution.
The question is, are you going to be doing any gaming on it.
If not, any video card that supports dual-link should suffice.
Such as this.
But if you're going to game with it, you'd atleast need a 8800GTX to even try to run at native with eye candy on.
Mwhahahah!!11!1...hahaha.... The only issue I see now is the PVA panel. If this monitor had a IPS panel..IMO it would be the perfect monitor for me...=(
OHH THE SORROW!
Do the Apple displays have a much higher color gamut? I have an Apple monitor, and even through the contrast ratio kind of sucks, I was always impressed by the color range.I'm stuck on the color issue, what I would be replacing is my wife's 2001 Apple 22" LCD display, so my biggest worry would that she would see a negative difference between her current Apple display and this Gateway with it's 72% color gamut. I'm thinking that I don't know, I was assuming that the Gateway would be fine, but I don't know what Apple produced 6 years ago and how it compares.
Really? Even the 30" models? I guess I need to research more into this, but I notice that there is no banding on my ACD in certain cases where banding might appear in my other LCD displays.Apple displays are 72% gamut from my knowledge.
What did you use to calibrate it? Something professional or something we consumers can use.
Can someone who has this monitor give us some idea how plain old text is on screen at the high resolution? How does 8, 10 point type look at say 20 inches....hard to read? Easy...I was thinking my wife would be using Leopard soon and had hoped that Leopard was using Resolution Independence, so the monitor would be fine at that super high resolution. But I found out that Leopard doesn't have it enabled yet....maybe some time next year, so now how easy it is to read the type is still important until that technology is fully implemented.
I have four 30 inch monitors on my OverDrive PC, two Dell 30 inch, the HP 30 inch and the Gateway 30 inch. I'm looking at a data model with hundreds of tables that I can stretch across all four monitors. I like the Gateway the best even on type, but the differences on type aren't huge. I've had the Gateway for about a month and it is my favorite overall monitor.
This is probably one of the most informative posts in the whole thread. There is nothing like a long-term comparative experience of competitive products in a user's home/work environment. That should just about cinch it for anyone still on the fence about getting this monitor. Thanks for letting us know.I have four 30 inch monitors on my OverDrive PC, two Dell 30 inch, the HP 30 inch and the Gateway 30 inch. I'm looking at a data model with hundreds of tables that I can stretch across all four monitors. I like the Gateway the best even on type, but the differences on type aren't huge. I've had the Gateway for about a month and it is my favorite overall monitor.
I have four 30 inch monitors on my machine, two Dell 30 inch, the HP 30 inch and the Gateway 30 inch. I'm looking at a data model with hundreds of tables that I can stretch across all four monitors. I like the Gateway the best even on type but the differences aren't huge. I've had the Gateway for about a month.
