tuksonrider
- Sep 29, 2007
Unless you've been living in a cave, I think everyone knows about the Cooler Master GeminII heatsink. One of the largest heatsinks on the market being able to house 2x 120mm fans.
The Kingwin Revolution RVT-12025 is much lesser well-known unless you've heard about the Xigmatek HDT-S1283. The Kingwin is a rebadeged Xigmatek and sold here in the US for $30.
GeminII w/ 2x 120mm 2000RPM 79cfm fans
vs.
Kingwin RVT-12025 w/ 1x 120mm 1500RPM 99cfm fan
TEST SETUP:
Intel C2D Q6600 B3 (2.4GHz, 3.0GHz, 3.2GHz)
EVGA 650i Ultra motherboard
EVGA 8800GT 512 (600/1500/900)
2GB (2x1GB 800MHz) PC2 6400
Corsair VX550W PSU
Antec 900 case
All fans full speed
Closed Case
AMBIENT ROOM TEMPERATURE: 21C (+/- .05C)
Prime95 tested small FFT: 15 minutes
VOLTS & SPEED:
With both tests, I used the exact same voltages:
2.4GHz
Vcore: AUTO
3.0GHz
Vcore: 1.312v
3.2GHz
Vcore: 1.343v
I kept an exact ambient room temperature of 21.0C throughout the tests monitoring it with a thermometer sitting above and in front of the case.
During the load tests, I ran Prime95, small FFT for exactly 15 minutes.
Results:
Cooler Master GeminII (lapped)
With a lapped base & 2x 120mm fans at full speed does okay. Idle speeds range from 38C-39C. During Prime95 load, the temps jump from 58C-70C. Thats not exactly impressive considering the size and weight of this HSF.
Here we see at idle, a -2C difference over the GeminII. This is pretty good considering its 200g lighter and only a single 120mm fan. Also, its much quieter. Putting a load on it, we see that the RVT-12025 does a MUCH better job at cooling the CPU across the board. At 3.2GHz, the RVT-12025 is a full 7C cooler than the GeminII.
Kingwin Revolution RVT-12025 = $30
Cooler Master GeminII = $30
Xigmatek HDT-S1283 = $40
vs.
TEST SETUP:
Corsair VX550W PSU
Antec 900 case
All fans full speed
Closed Case
VOLTS & SPEED:
2.4GHz
Vcore: AUTO
3.0GHz
Vcore: 1.312v
3.2GHz
Vcore: 1.343v
Results:
