I've got a HAVA Platinum HD connected to a 32in LCD TV in my office.
My dilema is that the TV has a built-in TV tuner. In order to use the HAVA and stream the TV, I need to have it connected to a set top box so I can change channels and such. The HAVA basically sits between the set top box and the TV, intercepting the signal. Since it doesn't accept coax, I need to run an RCA from a box, to the HAVA, then to the TV.
My question is: are there generic, cheap (e.g., Wal-Mart) set top boxes I can buy? I'm having a hard time finding some in online stores since I'm assuming they go under another name. I don't really need a quality product with bells and whistles since the signal is going to be streamed and compressed anyway. Just something that can grab a cable signal and output to RCA.
