Hey guys,
I've been taking my time the last coupla weeks trying to get gentoo to install on my monster machine, on the first (and failed) attempt (which took several days). I had not allocated enough diskspace for gentoo. Now I've definitely got enough, but a vexing problem is back from the last install that I dont remember if I solved it or not, or how....
From http://www.gentoo.org/doc/en/gentoo-x86-quickinstall.xml
Where it says ...
(Select a mirror) # mirrorselect -a -s4 -o | grep 'GENTOO_MIRRORS=' \
>> /mnt/gentoo/etc/make.conf
This command doesnt result in anything in the file...
(actually I just tried it to get the output to post to you guys and realized I had ( " ) instead of ( ' ) in the command.....but it still didnt work)
The output is:
grep: no such file or directory
Downloading a list of mirrors.....
/usr/sbin/mirrorselect: line 1: portageq: command not found
I will see what else I can do with it. Any and all help would be greatly appreciated...
Thanks in advance..
Where it says ...
The output is:
Thanks in advance..
