I'm looking to build a dualy server using mobile bartons. I know I'm going to need to pinmod these for the multipliers for them to run at a decent speed. There are lots of people on newegg and some other places saying the gigabyte board will take the mobiles and smile, but I haven't found anything about the tyan board. Anyone know if pinmods will work? or if it has multi adjustments in the board.
Also, as a general board, which one would you buy? The Tyan is $25 more and has less features, but I trust tyan more than I do gigabyte for server stuff, but people seem to have good stuff to say about the gigabyte.
Also, what would be a good PSU to use with these, would a antec 550w be overkill? And same for hearsinks, my current choice is a volcanno 10 for each, I'm looking to put this in a 3u rack box (that can take standard ATX psus. And do I need registered memory? or is that a nice helper?
sorry for the long rambling post, but to sum it up:
Tyan vs. Gigabyte (server vs workstation)
Which will mobile chips work better in?
Good PSU (numbers would be good on consumption)
Good HSF for 3u box
ECC memory needed?
thanks in advance
edit:
links for boards
Tyan @ newegg
Gigabyte @ newegg
Good HSF for 3u box
ECC memory needed?
thanks in advance
edit:
links for boards
Tyan @ newegg
Gigabyte @ newegg
