I wanted to check here for advice on doing an upgrade, my goal here is to keep the OS and not have to format and reload the system... Can you offer some suggestions. Below is my current and new hardware arriving this week. and then my plan of attack to upgrade which is where I'm looking for suggestions.
Intel D875PBZ MBD ---> Asus A8N-SLI
Intel 3.0 P4 HT ---> AMD 3200+ Venice Core
BFG 6800GT OC ---> eVGA n517 7800GT 470/1100
Samsung DDR400 ---> Corsair DDR400 (value)
Upgrade Plan:
* Uninstall Current Nvidia Drivers
* Uninstall Intel MBD/chipset drivers
* Uninstall Riva Tuner
* Reboot
* Install Nforce Drivers 6.70 - no reboot
* Install Forceware 81.95 - no reboot
* Device Mgr- view by connection - remove the PCI Bus, Intel processor, system board
* Power down system
* Swap out hardware & boot
* Let PnP detection take place (hopefully works?)
* Re-activate XP Pro.
Has anyone tried this, or do you have any recomendations or extra steps on doing this. I just have too much on my OS and everything is working great, I really don't want to spend days getting it back to where I like it.
Thanks,
Upgrade Plan:
* Reboot
* Power down system
Thanks,
