Hey guys,
I didn't think I would do it this year but since some friends are taking most of the parts of my current rig off my hands I'll move to the Intel platform and go with a Core 2 Duo setup. The sale of my processor, ram, motherboard, 1900XT and 850XT will fund the purchase of an Intel E6600, Zalman 9500 (I hear the 9700 requires a little modding to fit on the 680i), EVGA 680i motherboard and 2x1GB sticks of either Corsair XMS2 800 or G,Skill 800 5-5-5-12.
After doing a bit of research and looking at the OC chart I see that folks are getting some pretty decent overclocks with the Corsair and G.Skill memory which are 800mhz chips. These chips can be found for under $220 and with a rebate in some cases. Obviously the EPP stuff and 1000 or 1100 mhz chips will give me some more bandwidth but is it worth the extra $150? Will I really notice the difference between a possible OC of 900-950mhz with the 800mhz chips and 1000-1100mhz using the epp 1000mhz+ chips?
Personally I think it's overkill since at stock speeds this setup will kill my current rig anyway so everything else is just icing on the cake so to speak, but if it will make that much of a difference I'll spend the extra cash. I have an extra $500 to play with but I'd rather not spend it and wait to see how this video card war plays out later this year and keep saving for one or two of the next latest and greatest gfx card.
So, do I go crazy and get a set of insane ram or just go with some 800mhz stuff from the aforementioned brands, hope for the best and be happy with a mild ram overclock and possible awesome CPU overclock?
For those of you that are about to ask what I use my computer for, I play games, convert music and video files very often, work in Visual Studio 2005(Intellisense is a hog but indispensible), Virtual PC running DB servers, and I have a bad habit of leaving 20 browser windows open.
Thanks in advance for your input.
