body { font-family: Helvetica, Arial, sans; }
Well the problem is I want it to display well on both Mac's and Windows based machines and the way it is not it looks a whole lot better on the Mac than it does on my Windows desktop.
Verdana's also good, I think that's on both OSes.
We ended up using Calibri which came in Vista and is in OS X, so now all is well. Thank you guys.
What about XP?
On the slim chance that this isn't sarcasm, I'll say that you're half right.... There's still plenty of medium and large organizations still on XP. But I'd draw the line there, instead of optimizing for even older stuff like IE5.x, Mac OS 9, etc.Pssh, no one uses that anymore, it's years old!
don't forget that playing with the css line-height property can do wonders for making your text look better
btw, you can specify multiple fonts via css, and the first one that the computer has installed will be installed. So if you like Helvetica, but want to be able to fall back on Arial, you could do this. Should look good on Mac, PC and Linux...
Code:body { font-family: Helvetica, Arial, sans; }
Calibri is a great looking font that is very easy to read. Excellent choice.
I ended up doing this
body { font-family: Helvetica, Calibri, Arial }
This will generally be Times New Roman. Not advisable unless you have a serif fetishI reccomend not specifying a specific font and leaving it with the target machine's default.
OS X's font smoothing is very different from Windows'. Windows favors readability whereas OS X favors accuracy. Neither is correct, but type in OS X "looks better" while type in Windows "reads better".Well the problem is I want it to display well on both Mac's and Windows based machines and the way it is not it looks a whole lot better on the Mac than it does on my Windows desktop.
