KillerPotato
- May 14, 2005
After doing a quick search of the forums its apparent that these types of threads are made every other minute, so sorry for any annoyances.
Currently I have the Sennheiser HD570's and have enjoyed them thouroughly since I bought them several years ago. The only poor experience I've had with them is that I've had to send them in for replacement under warranty once when the right headphone became messed and would only occasionally play, and when it did, it would play the same as the left ear. Since then, the warranty has run out and any problems I've had I would have to open up and fix it myself finding out that a connection came loose or something, or the thin cable had a connection ruined at one point under the insulation and I would have to replace it.
My headphones are entirely for PC use, mostly for video games and a music, but after looking at the "upper echelon" headphone sites it seems that the HD570's are somewhat looked down upon for their price, so I feel like I've been missing out on alot, not having experienced higher quality headphones, so if anyone can reccommend a very nice pair for preferably less than 100. Comfort is a must which is one of the main reasons I like my 570's, so I would really like it if recommendations were around as comfortable. I listen to all types of music, and "warm" sounding headphones would be preferable.
As for either open or closed, I've heard that closed generally sound worse and more hollow, and I have a few other reasons for preferring open style headphones, but if there are some amazing closed headphones for a good price I would be more than willing to look (specifically the HD280's).
My other question is whether or not a good soundcard in my computer over onboard sound would make a bigger difference than higher quality headphones. Currently I'm using the onboard sound on an nForce 4 motherboard, and would like to buy the cheapest version of Creative's new X-fi soundcard, the simulated surround sound a big attraction. This is mostly an either/or situation since I dont have much of a budget.
So what good PC headphones can you recommend, and would a see a bigger difference with better headphones over the HD570's, or a stand alone soundcard? Thanks for any suggestions!
