SicKlown42012
- Jul 6, 2008
The prevailing opinion has been that if you're going to overclock an AMD processor, you need to disable Cool 'N Quiet in the bios. Well, after some problems using PhenomMrsTweaker, i decided to buck the trend. Using the same overclock settings, I turned to option on, and violla, my 940 is idling at 800Mhz at 1.000V. I now feel much better about running my cpu at such a high voltage.
I've done some more research on the subject, and from what I can tell, whether or not it works is dependent on which motherboard you have. For the record, i'm using An Asus M4A79 Deluxe (AM2+). So, hopefully i could have helped someone, or at least spread some more knowledge.
