i noticed in the book under the section "Installing AMD Athlon64 CPU Cooler Set" it shows you how to install the backplate, but when i look at the mobo its already on, in the manual it says remove the backplates paster, has the company already did this? or is it on there and i have to take the backplate off and remove the paster? thanks
Yeah, I started to try it but got frustrated and confused. I believe it's in the far bottome lefthand corner, near the orange colored slot. Again if you figure it out, message me please
if you look in that big manual i was tellin you about it will show you where they are, there the Yellow connectors next to the green ones which are under the orange pci slot, in the manual there called the Front Usb Connectors
That reminds me, I really must check and see if my Superlanboy front mic ports are hooked up to my Neo2. It's fiddly to hook them up (being in the corner of the case), but it is possible...it's all in the manual). Whether it's worth it is another matter...
Edit: Oh yeah, and paint the green card on the tool box with some silver paint - it makes it look so much better.
