alg7_munif
- Oct 9, 2006
Pictures? Pffft. Who cares.
We want overclocking results.
I won't be overclocking soon since the temp reading on M3A79-T Deluxe using the 0803 Bios is not working, the temp now is -256C. According to this, my CPU is cooling the other components.
I saw that and that's just INSANEThey were Johnny on the spot when the first-gen Phenom came out. Now that it isn't all stink, they have to dig deeper to find the suckage. But I'd rather they take their time and get it right; thoroughness is a virtue. By the way, did anyone catch this 6.7 GHz 955 BE OC? http://valid.canardpc.com/show_oc.php?id=551629
I want my PII case sticker, there is no sticker inside the box!!!
I'll post some pictures later.
Look in your manual for your sticker... that's where mine has always been
Sorry for the late reply, something came up so I need to get it done first.
Now I'm having a problem with my system, my system clock (time) is lagging. I was running 5050e before this and I didn't have this problem. By lagging I mean, if I sync my system clock with the internet, after an hour my system clock will be ~20 minutes behind the actual time. I notice that when running at 800MHz, the second hand on the system clock moves slower than normal. I'm gonna try disabling Cool n Quiet and see if it makes a difference. I just hope that this is just a case of immature BIOS and it will be fixed with a new BIOS. Another thing is, the "|" cursor when typing also moves slower than normal when I press the left or right key.
Btw I found my case sticker deep inside the manual. I bought a few Phenoms before but the case sticker was never buried deep inside the manual, normally it is inside the manual but I didn't have to unfold the manual entirely to get it.
We should really start calling them "PhII" or something else
nah Intel's processor has always been the Pentium, P2, P3, and P4.
Roman numerals are AMD's naming scheme.
Did you reset your bios when you replaced your proc?
Disabling Cool n Quiet fixed the clock and cursor issue. Hopefully a new BIOS will fix that issue since the idle temp with CnQ @800MHz is 44C compared to 49C @3.2GHz. Since CnQ can't be used, I fired up AMD overdrive, move the multiplier to 18x and now I have a 3.6GHz CPU at stock voltage. I'm running the AoD stability test now. I'm using the Thermalright Ultima 90 heatsink.
What am I suppose to read?
6.7Ghz on a Quad? Negative Ghost Rider, the pattern is full. CPU-Z shows it as Cores=2, Threads=2. I wish people would quit referencing this .
And alg7 congrats on 3.7Ghz. Thats a nice clock on any brand of chip.
