[LYL]Homer;1036317797 said:Aposium -
What size do you propose? 500gb and up? I presume large capacity SSD's are beyond the scope of this.
(WD does have the 1tb Scorpio BLue and Samsung has the HM100UI that are both 12.5mm in height instead of the standard 9.5mm size. I would break out the 12.5mm drives from the 9.5mm ones.)
i wouldn't see a problem with the drive height, as most server users wouldn't care about the height.
For example, my OS drive is a seagate constellation. the height didn't matter; bought an adapter for a supermicro CSE-M35 tray, job done!
another suggestion for the list, add a column for watts per TB for each drive. some of us are lazy and don't want to have to work it out.
