chickenselects
- May 18, 2006
Hey guys, yet another noob question for the forums
I plan on buying the following parts at the end of the month:
Black Ice Pro II Radiator
Aqua 1300
Swiftech MCW60 VGA Cooling Water-block with Ramsinks - Retail
GIGABYTE 3D AURORA GZ-FSCA1-ATB Black Aluminum ATX Full Tower
White Water from dtekcustoms
I know the aqua pump is cheap and most likely to break or leak so iv been looking at a dangerden pump (CSP-MAG).
Now the CSP-MAG is 143GPH and that Aqua is 370! I plan on cooling a conroe 2.4 OC'ed to 3ish (hopefully) and a EVGA 7900GT abit. Id like to get the CSP-MAG but does it boast enough GPH for my potential setup?
Also since im posting , what would be the best loop setup based on the case? I plan on using a T-line and mounting the Black Ice on the back of the case(fits perfectly for the dual 120 on back). I was thinking Pump->Radiator->CPU->GPU->Tline->Pump so the coldest water is always flowing directly to the cpu.
Thanks a ton.
Aqua 1300
Thanks a ton.
