Hi everyone,
I received a GTX 460 1 GB today and played some BFBC2, eager to see a large improvement in my frame rates. But that didn't happen.
With my 4850, I averaged about 40-50 fps at 1440x900 on high. With my GTX 460, my frame rates rarely went above 40. Oddly, my frame rates don't seem to change with the settings: 1024x768 on low will produce similar frame rates to 1440x900 with everything maxed. Also, gameplay is much choppier with my GTX 460, even when the frame rates are comparable.
Another thing I noticed is that whenever I load a map, the GTX 460 will move at a crawl -- about 3-5 FPS -- for ten seconds or so. The 4850 never did this.
The temps on my GTX 460 never go above 60C, and I tested it for about half an hour on Furmark, which it passed.
Here are the rest of my specs:
Core 2 Duo [email protected]
4GB Corsair DDR2 @ 890mhz
1 TB WD Caviar black (I used a 250GB Seagate with my 4850, if that's relevant)
Windows 7 Ultimate X64 (I used 32-bit XP with my 4850)
600W OCZ Gamexsteam PSU
Also, Crysis runs much better on my GTX 460 (about 50% higher frame rates), so I know the card can't be completely broken.
I'd appreciate any help, as I'm leaning toward returning a card that I would gladly keep if it performed as it should.
