lt_wentoncha
- Jan 20, 2005
Howdy all,
Alrighty, I'm getting impatient waiting for the GTX 480 to get out there. Rather than pay the $1000 people want on eBay (btw, to all you eBayers out there, real classy, buy a high
demand card so you can gouge).
I digress, what's the way to go, GTX 470 SLI or 5970? Two GTX 470s and one 5970 are priced the same. I told myself I would never do SLI, but damnation every vender is talking early may for the GTX 480.
I tried listing the Pros/Cons below...as you can see, there is a gap in my ATI knowledge. The only thing that's preventing me from jumping on board with the 5970 is Physx.
Target System:
*i7 930
*GA X58A-UD-5
*I have a GT 240 that I was going to pair up with the GTX 480 b/c I don't think it can do three monitors alone, might keep it strictly for Physx unless there's a bottleneck
*G.Skill PI 6GB DDR3 (1600) 7-8-7-24
*Crucial/Micron C300 128 GB SSD
*1x LG BR Writer
*2x 1 TB drives
*Hauppauge Win-TV 1850 Tv Tuner
*Corsair H50 Heatsink
*2x 120mm case fans
*Powering it all: Corsair 850TX
GTX 470 SLI
Pros
+Physx support
Cons
-Heat
-PSU (slizone oks the PSU...I'm not quite sure but there 72A on the 12+ rail)
5970
Pros
Cons
Target System:
*i7 930
*GA X58A-UD-5
*1x LG BR Writer
*2x 1 TB drives
*2x 120mm case fans
GTX 470 SLI
Pros
+Physx support
Cons
-Heat
5970
Pros
Cons
GTX 470 said:Chipset
Chipset Manufacturer NVIDIA
GPU GeForce GTX 470 (Fermi)
Core Clock 607MHz
Shader Clock 1215MHz
Stream Processors 448 Processor Cores
Memory
Effective Memory Clock 3348MHz
Memory Size 1280MB
Memory Interface 320-bit
Memory Type GDDR5
5970 said:Chipset
Chipset Manufacturer ATI
GPU Radeon HD 5970 (Hemlock)
Stream Processors 3200 (1600 x 2) Stream Processing Units
Memory
Memory Size 2GB
Memory Interface 512 (256 x 2)-bit
Memory Type GDDR5
