My recent rig is now made better by a Corsair H100i. As per instructions, I installed it at the top of the case, with the fans as intake fans. Since there was a 200mm fan on the top, I repositioned it on the side of the case as an exhaust fan. Outside of the 200mm fan on the front, I have no other fans running. My questions are as follows:
1. What configuration will give me the best airflow to keep my temperatures down?
2. Should I add a 120mm to the back of the case as an exhaust fan?
3. Since the HAF 922 is built like a sieve, can I get any kind of really good airflow?
My build is a Gigabyte GA-z87-OC, i5 4770K, Asus R280x in the first slot (i.e. closest to the cpu), Corsair H100i. Corsair 650W PSU, Kingston 120G SSD, WD Blue 1T HD, and of course the HAF 922.
Thanks!
Thanks!
