Need some good advice of you hard members.
Will be used most for work (photoshop, web site design, little video editing).
Gaming (COD:BO2, BF3, CS:GO, D3, SC2, C&C:Generals2, NFS, F1, Dirt3,...).
Should be as silent as possible.
Reasonable price, quiet build.
Austria, Slovenija
6) Will you be overclocking?
CPU will be overclocked.
GPU should be overclocked, but harder when SLI?
7) 7) What is the max resolution of your monitor? What size is it?
Dual screen setup, 2560x1440+1920x1080, 27"+27" or 27"+23". Gaming will be on the 1080p monitor.
Want to order this week.
9) What features do you need in a motherboard? RAID? Firewire? Crossfire or SLI support? USB 3.0? SATA 6Gb/s? eSATA? Onboard video (as a backup or main GPU)? UEFI? etc.
Sure some 5.1 audio, SLI, USB 3.0, SATA 6Gb/s and so on.
10) Do you already have a legit and reusable/transferable OS key/license? If so, what OS? Is it 32bit or 64bit?
I will instal Windows 7 Professional or Ultimate, is there a difference? Do i need one over the other?
- Primary LCD 27":
ASUS PB278Q
- Secondary right now Samsung 245B
I may replace it with:
27" Asus VG278HE (144Hz)
or
23" Asus VG236HE (120Hz)
I think 27" will be to big for gaming, I'm totaly used to the 24" right now, distance, but the 23" is not 144Hz.
- Asus Maximus V Gene
- 3570K (was first thinking 3770K, but will save here and maybe buy second GPU)
- Most silent pre build watercooler? And best cooling? Corsair H100 (CoolIT ECO)?
I read somewhere you cant do 5GHz overclock on this prebuild watercoolers. A 4,5 overclock would be nice.
What fans can i replace the original H100 fans? Need the most quiet ones.
- EVGA GTX 670 FTW, 2GB
Is this card 100% the better pcb than non "FTW" card? Because this one is 50 dollars more.
- maybe second EVGA GTX 670 FTW, 2GB
- Need Corsair 2x8GB = 16GB kit. Corsair Veneance 2x8? Or low profile ones?
- Best quiet, 750w, modular power suply
Corsair AX750, HX750, Seasonic X750,...
- Sennheiser RS 170 Wireless Headphones or some other Wireless Headset?
- Fractal Define Mini
- Samsung 830 Series 256GB, 6Gb/s
- Razer DeathStalker (not ultimate, no touchpad)
- NVIDIA® 3D Vision™ 2
- Razer Mouse bungee
- 2x Logitech Wireless Gamepad F710
I already have HDMI to 47" LCD for movies and it will be used for race, sport & fighting games.
Have 2x WD Caviar Black 640GB for storage.
Logitech G9x on Goliathus, Sennheiser HD 555, Logitech S220 & Logitech Z-5500 for movies.
Austria, Slovenija
- Primary LCD 27":
ASUS PB278Q
or
