Hi,
I've finally finished setting up my media centre properly. I bought a Hauppauge PVR150 with MCE remote and I'm loving the functionality that the MCE is giving me. It's just fantastic.
But, a major gripe I have is that the image quality just isn't the greatest. I have a digital set top box from my cable provider, with RCA outputs going into my Hauppauge card, then RCA outputs from my ATI 9700 pro into my 27" CRT. The STB also has a coax output which I'm using to plug directly into the TV. This way I can directly compare the image quality difference the HTPC brings.
Here are the problems:
1. The 9700 pro is compensating for overscan by outputting a smaller box. While this is great for using Windows and occasions when I need to see stuff in the corners, in general, it just cuts down slightly on the viewable area of TV/movie watching. Is there anyway to change the overscan for only when I'm using MCE? Maybe Powerstrip would do the trick.
2. I'm noticing some slight choppiness and some slight blurring on movement during TV watching. Also, the image quality in general just isn't nearly as crisp as without going through the tuner. It almost seems like it's in lower resolution. Is there anything I can do to improve the image? The Hauppauge CD didn't really come with much, just drivers really.
3. The remote came with an IR blaster which I'm using to change channels on the STB instead of on the tuner itself. It works fine, but lets say I'm on channel 12 and hit channel up, it will then send 0-1-3-enter to the STB, which causes a noticeable delay in tuning. Probably close to double the time to change channels which is annoying. Is there anyway to force MCE to just send a channel up signal instead?
Apart from that, I really love this thing. The guide is incredible and significantly better than my set top box's guide. The GUI is so slick, most options are super easy to set up. I really want to use my HTPC for all my TV watching but if I can't fix these problems, I'm not sure that I'll be able to.
Thanks in advance,
Adrian
Thanks in advance,
Adrian
