GaleForce
- Aug 7, 2004
I am looking around on monoprice at the moment to purchase an HDMI cable but they offer quite a few. I know for a fact I don't need ethernet support nor do I need the cable to be CL2 (I believe). What I do need to know is if I need a higher speed cable or if I need a specific AWG. Also I know that high speed cables will support any format, according to monoprice, but obviously the only video formats I will be running from my PC to my TV would be avi, mp4, and mkv.
And just for some more information, I have separate speakers for my computer and for my TV. What I was planning on doing was getting an optical out sound card (just whatever cheap one I can find) so that I can run an optical audio cable from my PC to my TV's speakers. I don't want to use the audio over the HDMI because I assume that will only carry audio to the TV's built-in speakers (HDMI will hook up directly to the TV as I don't have a receiver).
Anyway I am basically just looking for a simple setup and don't mind running 2 cables.
Would this be sufficient: http://www.monoprice.com/products/p...=10240&cs_id=1024009&p_id=2529&seq=1&format=2
I'd even go with this, however I don't think the max cable length they offer for this product is enough for me to effectively run the cable without seeing it: http://www.monoprice.com/products/p...=10240&cs_id=1024008&p_id=3993&seq=1&format=2
Thanks for any help you can provide!
