Hi,
I've just set up my first HTPC. It's a P4 2.4 ghz, 512mb ram, ATI 9700 pro powering a 26" Samsung CRT that's about 5-10 years old. I'm looking to make the plunge to HD soon but the more I read on the subject, the less sure I am of any decision. The TV will be used almost exclusively for TV and movie watching. At this point I very much doubt that much/any game playing will be done on the TV. I have my Dell 2405 for my main computer and if I were to get an Xbox360/PS3, it would most likely be connected to that so as not to tie up the main TV. Ideally, I would not be spending more than $3000 Canadian on this TV after taxes. Another consideration is that the TV will be placed in the living room, with a large window about 5 feet to its side, putting it in a high ambient light situation for most of the day and the blinds will block the direct sunlight but won't cut down on the ambient light very much.
Here are some of my questions:
1. Which TV technology is best suited for my needs? DLPs are the most attractive as far as price/size/performance go, there's no doubt about that. I'm just really worried about the ambient light levels. Anytime I've seen a DLP in store (same goes for LCD rear projection), I've been pretty unimpressed with its brightness and angle viewing when there was a lot of lights around. In the darker back rooms, they look fantastic, but this worries me. LCDs look awesome to me but everyone keeps saying that Plasmas are still king for home theatre. Not saying that Plasmas look bad they're just ridiculously expensive still, more than twice the price of DLP.
2. I'm going to be sitting about 8' from the TV. I've been looking at 37"-45" LCDs, 42" Plasmas and 50" DLPs. How bad is SD gonna look on 50" from that distance? And at the opposite end, would I even notice the difference between 1080p and 720p on a 37" from that distance?
3. How important is 1080p considering my needs? Ideally, my set would have it, but I'm thinking for TV and movies, it probably won't make a huge difference, especially given the lack of 1080p programming for the next few years. What about de-interlacing of 1080i signals?
That's pretty much it for now. Not sure if this is the best place to post these questions but I've been looking around on avsforum.com and it seems like most of the people there are on their 8th HDTV already, so it's hard to get a good description for a noob like me.
Thanks,
Adrian
Thanks,
Adrian
