Has anyone heard of heat issues with the PD820? I've tried looking around a little but haven't found much. My 820 is running around 60C with an intel d945psn mobo, AC Freezer 7, AS5. I just applied AS5, and realize I have to let it set and the temp will go down a little.
It's in an Ultra X-Infinity case, I also have a 120mm and 80mm intake behind and next to the HSF and 3 80mm exhausts on the top and front of the case. There's an Ultra X-finity PSU with a 120mm fan directly above the HSF too that blows up and out. I have an Ultra fan commander CPU temp probe taped to the base of the heat pipes by the CPU and it reads roughly 42C at idle.
The BIOS and Sandra(07 lite) both display CPU temp around 60C and the ambient temp in the room and system is about 27C. The board temp via sandra is about 40-42C.
Any comments or helpful links would be appreciated.
Rest of the specs in case needed:
Seagate 160 GB SATA2
EVGA 7800GT
Audigy 2
External Stuff (HDDx2)
EVGA 7800GT
Audigy 2
