ok.. im in quite the dilemma... im going to be ordering an LCD within the next couple days and the budget is $400 and nomore...i should also include that i am a pretty big gamer.. i plan on keeping the CRT on my desk and running dual monitors depending on how i can rearrange my desk...
now i have narrowed everything down to two choices...
19" BenQ FP931 - http://www.benq.com/display/lcd_fp931_specs.html
or
17" Samsung Syncmaster 710T - http://www.samsungusa.com/cgi-bin/nabc/product/b2c_product_detail.jsp?eUser=&prod_id=MJ17BSABY&selTab=Specifications
here are some quick specs, and both monitors support DVI and are native at 1280x1024.
19" BenQ FP931
Pixel Pitch (mm) 0.294
Brightness 250 cd/m2
Contrast 450:1
Viewing Angle (H/V Degrees) 130/130
Response Time 16 ms
Display Colors 16.2 million
17" Samsung 710T
Size 17"
Pixel Pitch (mm) 0.264
Brightness 300 cd/m2
Contrast Ratio 600:1
Viewing Angle (H/V) 160/160
Response Time (ms) 12
Colors Supported 16.2 Million
i appreciate all feedback but i prefer it be kept toward the topic .. so straight up, which monitor would you choose, whats more importnat.. the clarity and performance or the size.. thanks guys
or
19" BenQ FP931
Contrast 450:1
Response Time 16 ms
17" Samsung 710T
Size 17"
