hi forum,
i think i am in need of a new computer because my old amd 1800+ just doesn't seem to cut it anymore and my g4 mac is ok but not super quick.
i am going to be starting a new job with a new company soon that involves using photoshop and freehand a lot. the main emphasis is designing print based media.
the computer will also then be used for side projects that involve creating websites / photo manipulation / video work / light sound creation and other multimedia related things.
i have looked at the 2.0/2.3 dual powermac which will cost around £1115 - £1500 depending on what configuration i go for. the problem is that i do not want to spend loads of money on the powermac as macs are moving to intel within 1-2 years and this could mean my invested purchase could go obsolete quicker or annoy the hell out of me because i have older ppc technology.
this got me thinking. i could go a windows/pc route and then switch back to apple in the future. i could buy a ready made pc from various manufacturers but i rather build my ultimate machine. could you please help me spec a fast/quick multimedia pc? my budget is around/max £1000-£1250. i do not need a monitor as i have a decent crt and tft for dual monitor set-up.
my main needs are that it needs to be fast as fast can be for my budget. it needs to be whisper quiet as possible (macs are so quiet so on a similar level). offer good expandable options for the future such as more ram/hdd.
any configuration advice for my needs is appreciated. cpu/motherboard/case etc etc
(have been advised to look at the new amd x2 cpu as its meant to be good, but i will request your help on what cpu for my system)
thanks,
thanks,
