Dead cpu and/or MBkevin1211 said:ok, when i restart/turn on my computer i get the following message:
IDE channel 2 no 80 conductor cable installed.
Cpu is unworkable or has been changed
what is the problem?? i havent touched anything in my computer
I'd say the first message has always been there and you just didn't notice it. It's a common message if you're using an ata66/100/133 device with an old ata33 cable.kevin1211 said:IDE channel 2 no 80 conductor cable installed.
coffee33 said:Dead cpu and/or MB.
Isn't that exactly what I said already?Epicenter said:Uh, no. That's very, very wrong.
Reset the CMOS settings and it should go away. The 80-conductor cable complaint is that you have older 40 conductor IDE cables on your drives. For a possible speed boost you can change them for 80-con. versions for about $4. I'm sure that error was there before this little incident.
spine said:Isn't that exactly what I said already?
Yep, yep, thats why I edited my original post before I went to workEpicenter said:Uh, no. That's very, very wrong.
