OK I set up a 1gig Ramdisk drive with the hopes to run an XP VM at work.
I don't have an XP disk only the I386 file, how do I install using this on a VM?
Also running the VM from a Ramdisk drive will not use any harddrive recourses correct? (5400rpm laptop hard dive + VM = lame)
running Windows7 64bit if that matters any.
Thanks,
Thanks,
