First some background. I have a little experience with water cooling from like 10+ years ago.
After release, I will be building a sandy bridge rig with a 2500k, some later to be announced motherboard, and a 570 video card.
At completion, I am looking to water cool the CPU, GPU and if needed the mb, but I will start with only the CPU with plans to add the GPU and possibly add the MB later. I plan to OC the CPU and I do not plan to go SLI.
The only item that I currently have for this build is an Apevia x-jupiter case.
http://www.newegg.com/Product/Product.aspx?Item=N82E16811144203&cm_re=jupiter-_-11-144-203-_-Product
What I am looking for is a complete list of what components I will need to build this water cooling system and the best place(s) to purchase the parts from.
My budget is a FLEXIBLE $350 for just CPU cooling.
