blacklotus
- Apr 26, 2006
budget is $400 (can be bump up if not enough)
just need:
CPU (prefer Intel, but can go with AMD)
MB (prefer matx, but can go with ATX)
RAM (which ever is best for the MB)
PS
HD (80G would be fine)
CASE
don't need:
VIDEO CARD
OS
CABLES/ACCESSORIES
OPTICAL DRIVES
MONITOR
This computer would only be use for web browsing, light photo editing, light video editing and dvd burning. Don't need fast computer for these task as long as it can do the job. No gaming as of now, but might consider buying a video card later on so MB should be able to handle the add on card.
Thank you very much.
just need:
PS
CASE
don't need:
VIDEO CARD
OS
CABLES/ACCESSORIES
OPTICAL DRIVES
MONITOR
