I'm planning on building this system but I don't know which motherboard to choose. I don't plan on doing OC. If I do, it will be very minor OC. The rig will be used for gaming and developing 3D games.
Case: Silvertone Fortress FT02B-W (to buy)
PSU: Corsair HX850 or HX1000 depending on what is needed (to buy)
VGA SLI with 2x EVGA GeForce GTX 460 Fermi 720MHZ 1024MB 3.6GHZ (bought)
SSD: Intel X25-M 120GB 2.5IN SSD SATA II (bought)
HDD: RAID 1 with 2x Western Digital WD20EARS 2TB SATA2 (bought)
CPU: Intel Core i7 950 (to buy)
MOBO: ??
RAM: I'll look into that when the motherboard is selected
SB: Audigy X-Fi Xtreme Fidelity (would like to use it from my current PC) edit: I previously stated it was a 2-ZS but it was a mistake
If it wasn't for the sound card, I would choose one of those 3 (in order of preference):
ASUS P6X58D-E
Gigabyte X58A-UD3R
ASUS Sabertooth X58
Is there any motherboard that have room for a sound with a SLI setup? That would have to fit inside the FT02. Do I need to pick a LGA1156 instead so that I have room for it?
Should I just forget about using my sound card and let it rot inside my soon to be old computer? If so, which one of the 3 X58 boards has the best sound? What is your preference in those 3?
Thanks for any advice!
MOBO: ??
ASUS P6X58D-E
Gigabyte X58A-UD3R
ASUS Sabertooth X58
