I'm looking for an HDTV to get and looking at some of the cheap options. What would you guys recommend? I will use the TV mostly for, well, viewing cable TV. I might at some later point connect a HTPC to it, but not sure yet.
Cheap brands that I've seen so far:
- Olevia
- Vizio
- Sylvania
Should I also consider some of more well known brands? Not sure about budget, hopefully $800 or lower.
- Olevia
- Vizio
- Sylvania
