KnishofDeath
- Aug 27, 2004
So to all the watercooling experts out there....
explain this to me if you don't mind....
is there a way to attach two barbs or compression fittings together? Like a coupler of some kind?
I am looking for a clean way to pass 1/2" ID / 3/4" OD tubing through the midplate of the TJ07, without the use of grommets. I would like to mount fittings on the midplate if possible and pass the water through that way.
I have seen Charles (murderbox) do this by threading the midplate with BSPP 1/4" threads, but I am confused about how it is connected on the underside, is there another fitting attached somehow? I would be worried that would not be water tight?
Any help is appreciated, thanx!
