Hello friends!
I just put together a computer with the following:
Opteron 165 (CCBBE 0610DPMW)
ASRock 939Dual-SATA2
Zalman CNPS9500 LED
and Corsair Value Select 1GB(2x512) PC3200 (2.5-3-3-8)
It's all inside of an Antec P150 with a NeoHE 430watt PSU
Now, I went on a little adventure trying to OC for the first time,
and here are my results.
The ASRock's Bios only allows for a voltage of 1.400v, but CPU-Z displays
thats the voltage is running at around 1.44.
The Bios only allows me to set my HTT to a maximum of 300.
The only memory dividers that are allowed to me are:
DDR266 (3/2), DDR333 (6/5), and DDR400 (1/1)
Trying to OC at 1/1, I can get my HTT to about maybe 240 max, then
the computer wont even start. Probably because the RAM cannot handle it.
So, I tried 6/5, and my max HTT is 272, which Primes both cores at 8 hours+
(no errors yet, but I had to stop) This yields 2448mhz.
Now, i tried 3/2, which theoretically, if I set my HTT to 300, the RAM should
follow and be set to its normal 200mhz. Well, any number i try for 3/2 does not
work.
Anyone know what i can do? or is 272 HTT, with 6/5 ratio my max?
Zalman CNPS9500 LED
work.
