mikeohara
- Dec 24, 2002
I currently have a Zotac GeForce GTX 580 3gb card, and I'm looking to upgrade to current-gen graphics technology (i.e. 7970/680 cards). I have a budget of $600 to spend on the card according to my wife (note, I said single card) and have my eye currently on both the MSI Twin Frozr 680 (out of stock atm) and the Asus DirectCUII Radeon 7970 (in stock) as possible purchase options. They're both available at Newegg in the price range I mentioned above.
Highlights:
a.) I game at 1080p resolution. I want to experience high-quality graphics in games like Battlefield 3 with everything possible maxed out (AA and AF included to some extent).
b.) I'm looking at purchasing within the next 30 days, so I have a little bit of time to kill before making the purchase, and hopefully time for 680 stock to be received at Newegg again and not sell out as quickly
I currently use the system below in my signature, and could use some help picking out a new card. If you have a card other than those two that you want to suggest, go for it! I'll take all reasonable suggestions under advisement. Also of some note, I do have a red and black cover scheme in the inside of my case going on, so if you want to suggest something that adheres to that theme, that'd be awesome!
Thanks!
Highlights:
Thanks!
