I have this Case.
http://www.koolance.com/water-cooling/product_info.php?product_id=273
First question regarding the included laing ddc pump, how can I tell if its the 3.1 or 3.2 version? The 3.2 appears to be much more powerful.?
What radiators are compatible with the shroud that is included in this kit?
Swiftech MCR320? Maybe a black ice extreme 360 (with probably a riser so it will let me use my pci slots).
My System Is as Follows.
e8400, evga 680i, evga 8800gts 512 mb , wifi pci card, and x-fi fatal1ty
7 Hard drives, and a dvdrw. and some ocz flexx lc ram that will be upgraded to some 4 gb kit.
I have already purchased a ek 680i N/B Block. I intend to purchase one of the mosfet blocks. (the larger one).
Is it necessary to watercool the south bridge? Or can I get away with using a passive block from thermalright or some other company?
Would it be realistic to use mcr320 + another 120mm rad mounted on the rear fan mount, to cool the n/b, mosfet, cpu, and possibly 2 gpus? I will more than likely hold out for the gt200, and not go sli.
nes
nes
