So I bought a 3200+ / Msi Neo Platnium last Friday and I need some advice on OC'ing it.
Complete Specs:
Athlon 64 3200+ (New Castle)
2x512 XMS1024-3200LL
Msi Neo Platnium Bios 1.3
Bfg 6800 Ultra
80G Western Digital
Antec 430 True Power
First off the neo seems to be reporting the wrong temperature ~45C Idle / 60C Full load I'm using stock cooling with AS5.
I tried to overclock it every way I could think of. I've been using a 5/6 divider on the ram to rule it out.
Maximum speeds before windows freezez is 2500mhz. I get errors in prime95 above 2450mhz.I got a stable overclock at [email protected] (Prime95 ran for 16 hours without problems)
Even tried 1.60 Volts @ 2450 but that didn't work. Errors in Prime95 after a few minutes.
I also tried lowering the multiplier to 10x switching the HTT to 3x/245mhz but that gave me the same results. Crashes windows at 2500~ Unstable in Prime95 after a few minutes.
So what other options can I try? Would raising the voltage more help any? What voltage can these processors "safely" take? If I could run 250mhz on HTT this would allow me the run the ram at 5/6 with really tight timings at ~208mhz.
Running at 2400mhz with ram at 2-3-3-6 has almost no performance improvement to running 2200mhz at 2-2-2-5.
Complete Specs:
Bfg 6800 Ultra
80G Western Digital
