craigdeguz
- Oct 12, 2005
Hey guys,
So im gonna make a new build to get ready for DX10 and this is what I have chosen so far. My current build is in my sig. The only item im not sure about is a case. My current case is thermal take xaser and im not crazy about it. This system will be mainly for gaming and general computer usage:
Monitor UltraSharp 2407WFP 749
Proc Intel Core 2 Duo E6600 Conroe 2.4GHz 4M shared L2 Cache LGA 775 Processor - Retail 315
Fan ZALMAN 9700 LED 110mm 2 Ball CPU Cooler - Retail 59.99
Mobo EVGA 122-CK-NF68-TR LGA 775 NVIDIA nForce 680i SLI ATX Intel Motherboard - Retail 224
PS CORSAIR CMPSU-620HX ATX12V v2.2 and EPS12V 2.91 620W Power Supply 100 - 240 V UL, CUL, CE, CB, FCC Class B, TUV, CCC, C-tick - Retail 169.99
Vid card 8800gts 600
Memory BUFFALO Firestix 2GB (2 x 1GB) 240-Pin DDR2 SDRAM DDR2 800 (PC2 6400) Dual Channel Kit Desktop Memory - Retail 189.99
Hard drive Western Digital Caviar RE WD3200YS 320GB 7200 RPM 16MB Cache SATA 3.0Gb/s Hard Drive - OEM 99.99
Any way to make it cheaper or better? What should I do about the case, use the thermal take xaser or get a new one?
Thanks!!!
Thanks!!!
