SystemERRor
- Aug 29, 2004
I've been looking at the settings of Audio HQ, and there are some things thats confuse me. I have an audigy 2 zs platinum w/ the drive bay i/o drive.
Under the headphones tab, should i enable "Optimize 3d effects for headphones..." I have CMSS enabled, but im not sure what this does.
Under Decoder, what do i select? It was set on SPDIF Passthrough. I can also enable " Use installed decoder", but none of the options (such as Pro Logic) are enabled. Which should this be set at?
Also, should the Digital Imput or the Sampling rate settigns be changed at all?
