This is part of my case mod parallel HEX over in the worklogs forum. I thought I would post this here as it's still in the research stage and didn't want to clutter it with my ageing electronics knowledge! I'll post the result from this thread over to the worklog when the circuit has been built and finished.
I know this all might sound crazy, but bear with me!
The idea is to have Bulgin momentary led switches turn on an off a laser, the leds of the Bulgin switches and the leds of my fan controller. Switch 1 will control the laser and Switch 2 will control the Bulgin switch leds and the leds of the fan controller.
Starting from cpemma's design and the info gleaned from his very helpful website, I have the basic flip flop circuit to start with. I have kept the same format of drawings as cpemma throughout.
LASER CIRCUIT
Dealing with the laser circuit first of all, the laser requires 9V to run but the power requirement is unknown at the moment, but shouldnt exceed 1A. To add to the design, I only want the laser to come on when the led at the back of the Tagan PSU is lit. This blue led comes on when the psu load exceeds 20A. The voltage powering the blue led is between 5v to 12v, I cant measure this at the moment as my system is apart!
Ideally the circuit I build should be electrically isolated from the PSU led, and I have thought about 2 ways to do that. The first is using a phototransistor taped face to face with the psu led, so when the psu led lights, it activates the phototransistor.
Using a phototransistor:
For the laser to be on, S1 is pressed activating the 4013 output to high, giving voltage to the SFH300 phototransistor. When the phototransistor receives light from the psu led the TIP122 transistor is activated and the laser will be powered. Thats how I think it should work.
Things Im not sure of:
1. The need for the 3v zener diode before the lasers supply because of no.2 below.
2. The drop in supply voltage because of the TIP122 transistor (typically 2v).
3. The placement of the R4 resistor.
The second method I thought about was using an opto isolator.
Using an opto isolator:
The actual led of the psu is removed and the wires that supplied it connected to the anode and cathode of the opto isolator. A suitable resistor may have to be fitted in series as the optos internal led has different characteristics from the psus blue led.
When the 4013s output is high and the optos led is activated by the psu, transistor Q1 is activated allowing the laser to turn on.
More things Im not sure of:
1. The placement of R4 resistor again.
2. The voltage output at the emitter of the opto isolator is sufficient enough to activate Q1
3. The volt drop at Q1 and the need for the zener diode before the laser.
STEALTH MODE
The next circuit as mentioned before will control the Bulgin switch LEDs and the leds of the fan controller.
The leds of the Bulgin switches require a resistor and have different characteristics depending on their colour. I have 4 switches in the flowing colours:
Red Forward Voltage 1.85V
Green Forward Voltage 3.5V
Amber Forward Voltage 2.3V
Blue Forward Voltage 3.5V
(All rated at 20mA)
The fan controller is a 4 fan PWM type, and each fan circuit has 3 leds blue, green and red (low, med, high). The idea here is to remove the leds from the controller, mount them remotely, but switch them through a quad opto isolator, a TLP523-4. Since the fan controller has 4 fans x 3 leds each, I need 3 quad opto isolators.
The circuit above uses the other flip flop of the 4013 from the laser circuit. When Q1 (of this circuit) is activated from the flip flop, the Bulgin switch leds will light and internal leds of the opto isolators will activate. This will allow the leds of the fan controller to light as required.
Once the correct circuits above are sorted, the laser circuit and stealth circuit will be combined into one.
All help with selecting the best circuit, better components or corrections is appreciated!
Useful datasheets (some links are pdf's):
Bulgin LED Switches
Phototransistor SFH300-2
Transistor TIP122
Flip Flop 4013
Opto isolator TLP523-2 and TLP523-4, and a list.
LASER CIRCUIT
STEALTH MODE
(All rated at 20mA)
Bulgin LED Switches
Transistor TIP122
Flip Flop 4013
