Chameleoki
- Jun 28, 2004
I'm upgrading my game computer and have been out of the hardware world for a few years. After some research below is my build I need help with some feedback.
My Needs
- I am NOT an overclocker. I like speed/stability at stock. I don't have time to tweak.
- This computer will be ONLY for gaming. So I don't need a lot of extras such as firewire, etc.
- I want this computer to last for 1 1/2 - 2 years.
- I am building this around an ATI 4870X2
- I will not be doing crossfire but might upgrade to another single-card in a generation or two.
- I already have a 24" Dell monitor I will be using.
- I don't care about looks so I'm just getting a basic case.
- I have am targeting ~ $1000 (not including the video). I have some flexibility around this price so I could go a little bit over but I want the best bang for the buck where it makes sense.
My Build
Intel Core 2 Duo E8500 Wolfdale 3.16GHz LGA 775 65W - $189.99
http://www.newegg.com/Product/Product.aspx?Item=N82E16819115036
GIGABYTE GA-EP45T-DS3R LGA 775 Intel P45 ATX Intel Motherboard - $159.99
http://www.newegg.com/Product/Product.aspx?Item=N82E16813128348
OCZ Platinum 4GB (2 x 2GB) 240-Pin DDR3 SDRAM DDR3 1600 (PC3 12800) Dual Channel Kit Desktop Memory Model OCZ3P16004GK - $289.99
http://www.newegg.com/Product/Product.aspx?Item=N82E16820227297
Western Digital Caviar SE16 WD5000AAKS 500GB 7200 RPM SATA 3.0Gb/s Hard Drive - OEM - $159.98 (for two into a raid 0)
http://www.newegg.com/Product/Product.aspx?Item=N82E16822136073
Thermaltake W0106RU 700W - $149.99
http://www.newegg.com/Product/Product.aspx?Item=N82E16817153039
Antec Three Hundred Black ATX Mid Tower Computer Case - $69.95
http://www.newegg.com/Product/Product.aspx?Item=N82E16811129042
My Questions
- Is this a good motherboard for speed verses a X38/X48? Keep in mind I don't overclock.
- Is this enough PSU for my setup + 4870X2 and maybe a next-gen card?
- Am I spending money where I shouldn't be for little or no speed?
- Could I spend a little money somewhere else for better performance?
Thanks!
My Needs
My Build
My Questions
Thanks!
