spectrumbx
- Apr 2, 2003
Well, I was stoked about upgrading my two 2212 to two 8354, but the upgrade is not going smoothly.
I am able to boot and run fine with a single CPU, but using both CPUs, I get a "CPU mismatch detected!" error.
Both CPU have the same stepping (B3), but I see a difference in the second line marking that is on the CPUs.
CPU 1 is marked as follow:
OS8354WAL4BGH
GAAAB AA 0819MPMW
CPU 2 is marked as follow:
OS8354WAL4BGH
GAAAB AA 0824GPMW
From what I have been able to gather so far, there might be a slight voltage difference between the two chips, which is causing this.
My mobo does not allow me to change the voltage outside of increasing the default by 100mV.
Is there any mode I can make to the chips or mobo to make it work?
Thanks.
OS8354WAL4BGH
GAAAB AA 0819MPMW
OS8354WAL4BGH
GAAAB AA 0824GPMW
Thanks.
