My roommate currently has an old computer with an Athlon 1800, ASUS motherboard, 768MB RAM and Windows XP Home. He purchased it from a local store for $300. He only uses his computer to surf the net and play music, so can get by with an inexpensive computer. Anyway, I'm sitting at my computer reading the [H]ard forum when I hear... "Quick, come see what my computer is doing!" Oh boy... (BTW, I had him using AVG Anti-Virus so I don't think a virus was the problem)
Some backstory... he was having problems with the computer locking up about a month ago, and it progressively got worse. I am not a hardware person, but I tried to find out what the problem was. Booting in safe mode, the computer would freeze up after loading "mup.sys." Searching the Internet, I came up with an article that basically said the ESCD on the motherboard was corrupt, so I went into the BIOS and it had an option to reset the ESCD, which I used. The computer then ran fine for a couple of days, but then started freezing again. I told my roommate that I thought his motherboard was going bad, and I had no idea what to try to fix it, and suggested the next time he buy from the Dell Outlet store and get a real warranty. The store that he purchased the computer from wanted $80 just to run diagnostics. I've never built a computer... the most I've done is install memory, video cards and DVD drives. The next day he tried booting up again and everything was working, and had been working for the past week, until today.
Back to today... So I run upstairs to look at his computer, to find that Windows is installing from the Reinstallation CD I got for my Dell computer (which he had previously asked to borrow during the freezing problems). The installation then stops, saying an error had happened and Windows Setup had stopped so as to not cause problems. At that point, I figure his hard drive is hosed and that we'll have to format the hard drive and reinstall everything. Turning the computer off and back on, we get this screen (which was the one he originally saw before hitting F1 and then calling me upstairs):
Award Medallion BIOS v6.0, An Energy Star Ally
Copyright (C) 1984-2001, Award Software, Inc.
ASUS A7V333-X ACPI BIOS Revision 1002
Award Plug and Play BIOS Extension v1.0A
Initialize Plug and Play Cards...
PNP Init Completed
Trend ChipAwayVirus(R) On Guard
Detecting Primary Master ... WDC WD400BB-00DGA0
Detecting Primary Slave ... None
Detecting Secondary Master ... Hewlett-Packard CD-Write Plus 8100
Detecting Secondary Slave ... None
Primary master drive fails
Press F1 to continue, DEL to enter SETUP
10/22/2002-VT8367/VT8235-A7V333-X
Based on the prior freezing up and article from the Internet, I think his motherboard has gone bad, and that the problem is actually the HDD controller on the mobo instead of the actual HDD. But I really don't know for sure.
Is there any way to salvage this computer? Due to it's age, I don't know if we could even find a motherboard that would work. If we could find a motherboard, I suppose I could buy a book about Building PC's (any suggestions on that) or find a web site that has instructions.
So... any suggestions on what to do? Is it worth trying to fix, or should he just call it a loss and get something from the Dell Outlet store?
PNP Init Completed
