I have recently setup a server using a Intel® PRO/1000 PT Server Adapter. The current stable kernel in Ubuntu for my machine is 2.6.15-26-amd-generic. This kernel does NOT have the proper drivers for my NIC. I have downloaded the correct drivers from here:
http://downloadfinder.intel.com/scr...FullName=Linux*&lang=eng&strOSs=39&submit=Go!
In the readme file, Intel is explaining how to build, compile and install the driver into Linux. However, I am very new to Linux and I am not quite sure how to go about this. These are the instructions per Intel:
Building and Installation
To build a binary RPM* package of this driver, run 'rpmbuild -tb
<filename.tar.gz>'. Replace <filename.tar.gz> with the specific filename
of the driver.
NOTE: For the build to work properly, the currently running kernel MUST
match the version and configuration of the installed kernel sources.
If you have just recompiled the kernel reboot the system now.
RPM functionality has only been tested in Red Hat distributions.
1. Move the base driver tar file to the directory of your choice. For
example, use /home/username/e1000 or /usr/local/src/e1000.
2. Untar/unzip archive:
tar zxf e1000-x.x.x.tar.gz
3. Change to the driver src directory:
cd e1000-x.x.x/src/
4. Compile the driver module:
make install
The binary will be installed as:
/lib/modules/<KERNEL VERSION>/kernel/drivers/net/e1000/e1000.[k]o
The install locations listed above are the default locations. They
might not be correct for certain Linux distributions. For more
information, see the ldistrib.txt file included in the driver tar.
5. Load the module using either the insmod or modprobe command:
modprobe e1000
insmod e1000
Note that for 2.6 kernels the insmod command can be used if the full
path to the driver module is specified. For example:
insmod /lib/modules/<KERNEL VERSION>/kernel/drivers/net/e1000/e1000.ko
I am also trying to find this out on the Ubuntu forums but haven't gotten any good feeback as of yet.
With Ubuntu, I don't think the RPM tool is available. So, what is the correct way to do this in Ubuntu?? Can someone give some advice or point me in a direction where I might find step by step how-to info for installing these drivers??
Thank you!
of the driver.
cd e1000-x.x.x/src/
make install
modprobe e1000
insmod e1000
Thank you!
