I dont know what thread to post this in but anyways. I have mobile 2600+ barton with a ABIT NF-7 S. This morning everything was going fine, and then it just turned off. well i thought it was off, but the fans were still going. I tryed turning it back on and the fans just spun. Then unluged it, checked the ocnnections, turned it on again adn it worked. about an hour later it did it again, the fans just spun. so i checked all the connections and it didnt work. i unplugged and re plugged everything, change the plug configuration, put it back to normal. nothing works. now the red light on the mother board is on, but it wont even spin the fans.
anyone know whats the problem? i tried putting a paper clip in the green and black wires of my psu and nothing happened. do you think its PSU? Motherboard shortage? What is going wrong.the PSU is an antec 350 BTW, im not sure if i plugged the paperclip in teh right holes, but it didnt work. so im guessing its that, but it shuold be fine, i dont understand.
Thanks for help, Eben
edit: i reset the CMOS, now the fan just spins for a second and stops
