IronChefMorimoto
- Apr 14, 2002
I'm running the following:
- Shuttle XPC Sk83G (BIOS 29 - updated today)
- Athlon64 3400+ (Newcastle)
- 1GB PC3200 DDR (Crucial)
- 200GB Maxtor DiamondMax SATA hard drive
- 8X Lite-On DVD-R/RW drive
- ATI Radeon 9800 Pro 256MB
When I first set up the box last night, I was running the original system BIOS. I updated it with little or no change in idle temps. Want to get that issue out the way from the start.
Today, I installed all the components and booted the machine without the cover on. Idle temps went from 50 C to 55 C. I left the CPU FAN SPEED MODE in "quiet mode" rather than "safe mode" and installed WinXP. Temps got up to about 57 C - 59 C, according to the BIOS readouts after a reboot.
This IS my first processor with a heat spreader, and I'm not sure if I installed the Arctic Silver II correctly. I originally tried Arctic Silver Ceramique, but when I first saw the high idle temps, I was afraid I'd not applied it correctly and went BACK to Arctic Silver II. In fact, the Ceramique was so tacky that it pulled out the Athlon64 when I went to remove the heatsink/heatpipe.
In both cases, I DID NOT spread the heatsink compound all over the heat spreader, as the instructions from the Arctic Silver website recommended putting a 1/2 BB size amount onto the heat spreader and letting the heatsink spread it out. PLEASE CONFIRM -- is this the way that it should be done, or is the heat spreader not getting adequately covered.
I'm reading on SFFTECH.com forums abouts temps that vary from idling in the 50s to idling down in the low 40s. So far, the only thing that I can think of as the source of the problem is the thermal compound issue. If that's not it, what am I doing wrong?
Thanks,
IronChefMorimoto
Thanks,
IronChefMorimoto
