managerman
- Jul 26, 2004
Hello,
I just completed by new rig (specs below) and I have a question....
I have a huge jump in CPU temp from idle to Load...I am pumping a lot of volts (1.55) through the chip and it is Prime stable at 3.8 Ghz but, the temps (according to AI booster) are this: idle 40C and Dual Priming Load 67C!!
I am watercooling so not sure If I have bad contact between the block and the CPU or for my situation is what I am seeing normal?
This is one fast CPU...I will post some screens after work today...
Also I have been seeing a lot of posts about the X6800 hitting 4Ghz with little problem...Hmmm...Is mine just the luck of the draw at 3.8?? The board will not post at 4Ghz.....Again this is Stepping B2 OEM not ES..
Thanks in advance for any advice...
-M
-M
