brycejones
- Jan 29, 2002
4ghz on air is nice. Hopefully the bench marks will hold up as well.
No, I'm telling you to act like an adult because you're swearing and acting like your opinion should be treated as if it were delivered down on stone tablets from Mount Zion. People are allowed to disagree with you (and with me, for that matter). I don't get offended if you do. You shouldn't either. It's clear that you have some valid points, but your previous delivery was offensive, and not because you were being pessimistic on an AMD forum. Heck, that happens every single day, from the owner of the site, no less...
Not sure what thread you're referring to... But MrFace had clearly read what you had to say, digested it, and stated that no one has drawn any conclusions just yet. Basically, he's saying what I'm saying, and that these OCs are impressive and unexpected, considering the fact that (going from memory here) the K7 was the last time AMD showed clockspeed equilibrium, and potential superiority (of course the K7 also had the advantage of having faster IPC at the time, but the big vendors were just too afraid of Intel, or too in love with the marketing kickbacks, to act on it).
You have a point. In answer to your question though, it meant that P4s used a boatload of power at the time, so much so that people were making jokes about using P4s to heat their homes. I suspect that we'll see similar jokes for Phenom II from people running 4Ghz on air.
It also meant that they were really good at certain tasks (media encoding, for example) while being really crappy at others.
Well, not entirely true. I mean it's true that an apples to apples comparison is the most valid. But for the benchmark warriors out there (of which I'm not one, by the way), I pose this question: What if you are able to get significantly higher clockspeeds on an Phenom II than you are an i7? Sure the i7 will do better clock-for-clock, but if you can clock the Phenom II higher, will the additional clock speed impact the final completion time of the test(s) in question?
All of this is really just hypothetical discussion.
Seriously if your not a fucking mod do not tell me how to post. There are mods for a reason and its not so you can tell people how to post. The owner of the site saw fit to allow cursing so if you dont like it too fucking bad.
I honestly don't think they are; I just think it's the best they can do right now until a next-generation architecture surfaces. They are effectively playing the only card they can. I'm sure they don't want to be in this position, and are probably doing everything they can to get out of it. One thing I would bet money on is that they're not settlingRight the old "intel for work amd for play" I really dont think AMD should settle for that.
You've seen an i7 hit 4Ghz on a stock air cooler?Based on what i have seen 4GHZ on air is not significantly higher than anything. Intels offerings have been easily attaining 3.6-3.8 ghz on air this whole time with quite a few actually hitting 4ghz.
So don't be optimistic, that's your choice. Just realize that others are allowed to be optimistic and reach an entirely different conclusion than you, and your swearing at them isn't going to change that.Honestly considering the core 17's are already hitting 4GHZ+ its really difficult to remain optimistic for the phenom 2
