Network Magic is currently on sale but you can take an additional 33% off. I just got the Essentials for $16.70.
At checkout, enter the code NMEasy for 20% off. Next enter the code myperks for an additional discount making your total about 33% off. I believe this will work for Pro too, but it doesn't work for upgrades.
This is the easiest way to set up a network for XP or XP Pro. It makes childs play out of what use to be a complicated task. Not really needed for Vista as much (much easier netwroking), but will work with it too if you want the pretty network map and easy controls.
