ikellensbro
- Feb 14, 2004
I'm just curious, system in sig, & it's not a question for me whether or not to upgrade, but when for me. Basically, how much will framerates/3Dmarks go up by w/ some low latency 3200?
The lower your memorys CAS rating the better your memory/system should perform.
At a 100Mhz bus speed CAS 2 performs significantly better than CAS 3. In this case, CAS 2 offered a memory bandwidth increase of almost 33% over CAS 3.
At a 133Mhz memory bus speed the memory bandwidth performance CAS 2 & 3 is about 15% or so greater at CAS 2. Its interesting to note that the RAM running at 100Mhz @ CAS 2 provided greater memory bandwidth that running the module at 133Mhz @ CAS 3.
Overall, running the memory bus at 150Mhz, @ CAS 2 provided the greatest memory bandwidth of all tests done (20% faster than CAS 2 @ 133Mhz), even greater than running both FSB & Memory bus at 133Mhz @ CAS 2, where the L1/2 cache speed would be at its fastest.
Latency is measured in terms of clock cycles. For example, a CL=2 part requires two clock cycles to respond, while a CL=3 part requires three clock cycles. Thus, CL=2 parts complete the initial data access a faster (only 2/3 or the time) than CL=3 parts.
CAS Latency. This sets the CAS latency timing of the DRAM system memory access cycle when SDRAM system memory is installed. Setting this to 2 will yield better performance, although may be less stable if your SDRAM is not CAS2 rated. 3 is slower & should be used when SDRAM isn't CAS2 rated or you want to improve stability.
7.5ns RAM are rated stable at 133Mhz, 1000/7.5=133. Although some are higher grade.
7ns RAM "technically" are rated stable at 143Mhz, 1000/7=143. Although some are higher grade and may go up to 147-150Mhz. Hand picked which are consider best grade of all RAM and are at least 150Mhz and may go up to 166Mhz!
CAS 2 versus CAS 3
At a 133Mhz memory bus speed the memory bandwidth performance isnt quite as significant between CAS 2 & 3 (Only about 15% or so greater at CAS 2). Its interesting to note that the RAM running at 100Mhz @ CAS 2 provided greater memory bandwidth that running the module at 133Mhz @ CAS 3.
RancidWAnnaRIot said:I don't think you can truely mark a number on that.. hard to tell.. as there are many variables.. you just gotta do it kid..
Subliminal said:Lol...too funny.
Don't worry about real world applications...just drop a few hundred dollars to make benchmarks go up...that's what life is all about!
