shockwave85
- Apr 29, 2002
I want to give my WinXP partition as much space as it needs, but no more than that. How small can I go?
Why?shockwave85 said:I want to give my WinXP partition as much space as it needs, but no more than that. How small can I go?
Phoenix86 said:Why?
I know people tend to want to partition their OS' main drive, but 95% of the reasons are not good. I understand the idea that you could wipe the OS and save the rest of the drive, but what about programs? See your seperating programs from the OS like you would user data (docs, music, movies, etc.)
See most people partition this way.
Part1 OS
Part2 Progs/data or data on a 3rd partition seperate of the programs.
*IF* you really want to partition, I would suggest doing things this way.
Part1 OS/progs
Part2 Data
Consider the programs married to the OS, it's much easier that way. When you want to reformat, you will have to reinstall the applications anyways if you blow away just an OS only partition because of the registry, so why seperate them? It's also not a 'clean' load since your using programs from your old load, so if your trying to trouble shoot, reinstalls don't "buy" you the same thing as a clean format.
primea said:I definetely agree, it will be more efficient if you get a small fast drive ... around 20GB for OS and Programs, then have a second large drive for data ....
chinoquezada said:I third that.
I would look at your data storage needs, then use the rest for the OS/apps. What are you going to do when you hit 40+gb in OS and apps? Game can be several GBs alone, esp when you start DLing maps, like with UT2K4.shockwave85 said:So perhaps I'll divide my 120Gb drive into two partitions, 80Gb for misc. files and 40Gb for Windows and programs.
ComputerBox34 said:I fourth that.
